Lamp Works 251-LED Glam 1 Light 25 Tall LED Table Lamp with Hardback
Features: Designed to cast light in a downward direction Multi way socket switch Includes easily replaceable 2700K 800 lumen (60W equivalent) LED bulb with full scale dimming range Hardback white fabric shade Dimensions: Height: 25" Width: 15" Shade Bottom Diameter: 15" Shade Top Diameter: 14" Shade Height: 9.5" Base Width: 8" Electrical Specifications: Bulb Base: Integrated LED Number of Bulbs: 1 Bulb Included: Yes Bulb Type: LED Watts Per Bulb: 9.5 Wattage: 9.5 Color Temperature: 2700k Lumens: 800
Click for Best Price »
Price comparison
Store Price
Build.com [show price]
Lamp Works 251-LED Glam 1 Light 25 Tall LED Table Lamp with Hardback Review
First Lamp Works I've owned in years and wished it hadn't taken so long. Very happy with my choice. Lamp Works 251-LED Glam 1 Light 25 Tall LED Table Lamp with Hardback is a great choice of table lamps.
Read more reviews »
